 Telephone
 Telephone speaker vol increase
cyberc
Posted - Apr 15 2010 :  10:20:06 AM  Show Profile  Reply with Quote
Hi
I copied this simple setup between 2 old analogue telephones: http://communication.howstuffworks.com/telephone4.htm
It works perfectly, however, it is very quiet when listening. This makes no real difference over 10 meters or 100.
Is there a simple way I can increase the volume perhaps by increase voltage or changing the resistor? I know our local telephone network actually runs on 12v - I am just nervous to try and break the phones.
Thanks
Rod
(Edit...Move to Telephone)
Posted - Apr 15 2010 :  9:54:03 PM  Show Profile  Reply with Quote
You found an extremely simple circuit. Most extremely simple circuits work poorly.
In Canada, the phone network runs off 48V to 50V, not 12V. A phone draws enough current to drop it to about 8V. If the circuit does not limit the current then the phones might burn up.
A phone line does not use resistors that reduce the levels, instead it uses transformers that pass audio without loss and pass DC to the phones.
