 Electronics Repair
 Car Audio Diplay Problem
tmho
Posted - May 21 2006 :  3:56:28 PM  Show Profile  Reply with Quote
The display of my car audio (radio and CD & MP3 Player) recently became very dim that I can hardly see. (I mean the "letters/characters" of the radio channel and song). Can somebody please give me some advice on how to fix the problem? I bought it about 2 years ago. The brand name is Dynex and is not a famous one.
Posted - May 23 2006 :  11:11:48 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
Probably a bad solder joint at the display. Resolder all the pins.
sergiosparks
Posted - May 30 2006 :  04:52:08 AM  Show Profile  Send sergiosparks an ICQ Message  Reply with Quote
some displays have incadescent lamp behind
them to brighten the display.These bulbs go busted also.You will have to open the front panel to check them.
tmho
Posted - May 31 2006 :  03:59:11 AM  Show Profile  Reply with Quote
Thank you very much. I will try your suggestions and advise the result.
abdo_87
Libya
Posted - Jun 17 2006 :  05:16:41 AM  Show Profile  Send abdo_87 an ICQ Message  Reply with Quote
helloo pleas send me solution for radio ripple problems
asd
rapsucks_07
Posted - Jun 23 2006 :  12:19:28 AM  Show Profile  Reply with Quote
Might sound stupid but have u checked ur cars dimmer switch most of the time the person who install it connects all the wires not that thats wrong if that was the problem remove the radio and cut or disconnect the orange wire
What More Do U Want From Me Im 17
tmho
Posted - Jun 25 2006 :  03:56:39 AM  Show Profile  Reply with Quote
Thank you for your suggestion. I also guess so. I tried to resolder all the pins except those from the CPU/IC. The problem still exists. The pins from the CPU/IC are too tiny that my soldering iron cannot do that. I believe it need a hot air gun which I don't have it. Do you have more suggestions for me?
tmho
Posted - Jun 25 2006 :  03:58:40 AM  Show Profile  Reply with Quote
Thanks for your advice. I have open the front panel. The lamps are okay.
tmho
Posted - Jun 25 2006 :  04:02:40 AM  Show Profile  Reply with Quote
Thank you for your advice. I install it myself. At the beginning, it was normal. The problem just happened around a few months ago.
Posted - Jun 26 2006 :  09:03:42 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
Is the display a VFD (vacuum fluorescent display)? If so, then it relies on a HV power supply to light it up. Have you checked the condition of the solder joints around the display itself? How old is the unit? These displays do wear out eventually.
