 Other
 Electrolyser
Posted - Apr 06 2004 :  7:19:14 PM  Show Profile  Visit wasssup1990's Homepage  Reply with Quote
I have seen heeps of diagrams on the internet showing me that you can get 2H and O out of plain water. Would this work? Or do I need distilled water? Salt is supposed to make the water conduct, but when you add salt it doesn't give out 2H and O. It gives out a very potent Chlorine smell, I don't want chlorine! I just want 2H and O, that is all I ask. Can someone help?
Posted - Apr 07 2004 :  09:40:20 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
Electrolosys is pretty simple. Put two electrodes into water, seperated by a short distance (a few CM works). Use a 30V supply, and apply power. Instant H and O.
Don't use salt. It will break down into chlorene (as you discovered).
Posted - Apr 07 2004 :  8:26:31 PM  Show Profile  Visit wasssup1990's Homepage  Reply with Quote
So do you mean distilled or tap water?
Posted - Apr 10 2004 :  06:58:19 AM  Show Profile  Visit wasssup1990's Homepage  Reply with Quote
Ok, it doesn't look like anyone will answer my last reply. I've just bought a 5A 30V $198 power supply from DSE. Thanks for the help Aaron, and it worked! I succesfully created pure O and H2.
Posted - Apr 12 2004 :  09:26:53 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
God forbid it takes a few days to get a response. Generally my weekends are taken up working on mine (and other's) RX-7s, so I only check the forum to make sure nothing bad is happening...
At any rate, I just have always used tap water. Distilled water is actually a pretty good insulator, so you won't get enough current between the electrodes.
Posted - Apr 12 2004 :  8:02:31 PM  Show Profile  Visit wasssup1990's Homepage  Reply with Quote
Gee, I didn't know that.
Posted - Apr 15 2004 :  06:40:01 AM  Show Profile  Visit wasssup1990's Homepage  Reply with Quote
I've noticed that when i dont put salt in the water, i get a very shotty amount of Oxy. & Hydro. Is thier a possible way to get much MUCH MORE bubbles, as that if water with salt?
Posted - Apr 15 2004 :  09:03:20 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
Salt increases the conductivity of the water...hence more action takes place. I wouldn't recommend adding anything, but if you crank the voltage and current, you will get more current through the water and hence more electrolosys.
Posted - Apr 15 2004 :  7:08:02 PM  Show Profile  Visit wasssup1990's Homepage  Reply with Quote
1. How will i get sufficient volts, lets say 50V out of my 30V Max power supply? I want as much bubbles to come to the surface of the water, as with salt in water.
2. Are platinum electrodes as good as Stainless steel electrodes?
da-g-dog
Posted - Apr 15 2004 :  8:32:07 PM  Show Profile  Visit da-g-dog's Homepage  Reply with Quote
Try a voltage multiplier or a second power supply in parallel with your current one.
hike master kyle
Posted - Apr 15 2004 :  9:07:59 PM  Show Profile  Visit wasssup1990's Homepage  Reply with Quote
Hmm, where can i find one, a schematic will help me know how the voltage multiplyer works. I could make my own, instead of buying one.
Posted - Apr 15 2004 :  9:46:29 PM  Show Profile  Visit wasssup1990's Homepage  Reply with Quote
Oh, and what is the best type of electrode i could use.
cirvin
Posted - Apr 16 2004 :  08:11:30 AM  Show Profile  Send cirvin an AOL message  Reply with Quote
Search google fo "Cascade multiplyer" or just "voltage multiplyer". Most voltage multiplyers need AC to operate, but they put out DC.
http://daxter12.topcities.com
Posted - Apr 16 2004 :  09:03:52 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
You don't. You will need to make a new supply. Also, please remember that at 50V, things start getting dangerous. If you can find a 40V transformer, simply put a bridge rectifier on it. You don't need filter capacitors or regulators.
No idea.
cirvin
Posted - Apr 16 2004 :  2:28:22 PM  Show Profile  Send cirvin an AOL message  Reply with Quote
Carbon Electrodes don't degrade like copper or steel, but they do add resistance to the power supply.
Posted - Apr 16 2004 :  6:53:03 PM  Show Profile  Visit wasssup1990's Homepage  Reply with Quote
So which type of electrode do you recommend? I've seen people on the net use graphite too, they got it out of lanturn battery.
