 resistor question
whooshdoo
Posted - Sep 10 2011 :  8:35:41 PM  Show Profile  Reply with Quote
I have a 1/4 watt resistor rated at 1k ohms in a circuit and it is showing 12 volts at one end and only .4 volts at the other end. Since that is such a drastic difference in voltage levels, I am wondering if that is normal or could the resistor somehow have too much resistance? Is there a way to tell roughly what the difference in voltage should be across a resistor based on its rating? Thanks very much for any help.
JUAN DELA CRUZ
Posted - Sep 12 2011 :  05:40:58 AM  Show Profile  Reply with Quote
You should desolder the resistor first and measure its resistance based on its color coding. Isolate the component/s being tested.
BTW.. Are you sure its a resistor? ...or a DIODE?
juan dela cruz
Penniless INVENTOR
