 Time Delay Relay - Project
Previous Page
Page: of 3
KMoffett
Posted - Nov 25 2010 :  11:10:35 AM  Show Profile  Reply with Quote
Mis-wired and/or a blown 555. Did you place a resistor in series with the LED to limit the current?
Ken
foggyeyes
United Arab Emirates
Posted - Dec 06 2010 :  10:10:38 AM  Show Profile  Reply with Quote
Yes. Im using a resistor now.
There's a new problem now. The timing works fine using only an LED. Bnut when I use a relay in pararell, The circuit doesnt turn off. Even using JUST a relay, and NO LED doesnt solve the problem/
jeal22
Posted - Feb 18 2011 :  08:02:32 AM  Show Profile  Reply with Quote
This is the project given to us by our professor:
"It is required to start and run the three 12Vdc motors in sequence using one master START and RESET push button/switch. Once the START button is pressed, motor1 must start to run and followed by motor2 and followed by motor3 with 30 seconds interval from each motor. "
Can i use this http://www.aaroncake.net/circuits/relaytim2.asp?showcomments=all as reference ? and the next problem is that what's next after motor1 started? Can I use the same circuit as given?
Posted - Feb 18 2011 :  08:28:17 AM  Show Profile  Reply with Quote
Originally posted by jeal22
Can i use this http://www.aaroncake.net/circuits/relaytim2.asp?showcomments=all as reference?
As we discussed in this thread, the circuit is too weak to drive a relay. You should use a 555 timer IC instead.
Posted - Feb 19 2011 :  10:23:41 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
Cascaded 555s, or a 555 pulsing a counter. Very easy to do.
But as it is assigned by your professor, it is your responsibility to do the work. So look upthe 555 datasheet, and then look up a counter IC (4017). Then figure the rest out.
Page: of 3 Previous Topic Topic Next Topic
Previous Page
