 Other
 ATD and DTA
Posted - Jul 20 2004 :  10:11:24 AM  Show Profile  Reply with Quote
I would like to use ATD converters for the following application: The ATD is plugged inside a computer. The input to the ATD is a set of 5V lamps. The status of the lamps (ON/ OFF) is to be captured into a database on periodic intervals. The database contains fields like lamp ID, The Status of the respective Lamp and the Timestamp.
Tan anyone help me to design this circuit please?
[size=5]
Chamkeeper
Posted - Jul 20 2004 :  9:00:50 PM  Show Profile  Reply with Quote
Why and A/D converter? If you are only detecting on/off condition then the there is no need. Depending on how many lights you want to monitor, a simple vb program connected to the paralell port might do everything you need.
Posted - Jul 23 2004 :  03:11:26 AM  Show Profile  Reply with Quote
Thanks for your reply. But I want to extend this ON/OFF reading from switch to a Light Sensitive device. So would like to use ATD. Please help me to do this.
Btw: Could you please let me know how to read the ON/OFF status using VB/ C language using Parallel Port.
Thanks in advance.
YS
Posted - Jul 23 2004 :  7:25:37 PM  Show Profile  Visit YS's Homepage  Reply with Quote
light-sensitive device can make TTL output. Still no need for ADC unless it is your school requirement. Use printer port.
Chamkeeper
Posted - Jul 25 2004 :  12:30:46 AM  Show Profile  Reply with Quote
EVERYTHING you need to detect on/off using a paralell port is on this site, in great detail.
