 help plz!
Josh Posted - Feb 01 2005 : 7:23:59 PM
does anyone no where ill find something hot enough to melt diamond?
Kale Posted - Apr 30 2005 : 6:12:01 PM
Here's some diamond deposition links:
http://staff.aist.go.jp/f.tappero/diamond.html
http://www.cvd.louisville.edu/Research/Diamond%20CVD/Diamond.htm
http://cabernet.esprit.ec.org/esp-syn/text/6106.html
wasssup1990 Posted - Apr 30 2005 : 05:27:14 AM
COOL! This is very interesting.
J.C.
Kale Posted - Apr 28 2005 : 4:08:37 PM
Crystals can be 'grown' directly onto surfaces. It involves blasting a chemical soup vapor at a surface under very tightly controled conditions in a vaccuum chamber. The chemical vapors start to coat the surface and self-arrange into the crystal structure.
wasssup1990 Posted - Apr 27 2005 : 03:41:44 AM
I think they put diamond on those massive drills that bore holes in the earth.
J.C.
BEatonNo1 Posted - Apr 26 2005 : 2:35:52 PM
I know how its done for cutting applications, but have you seen where they put a thin film on a surface for berings and other low friction applications?
I there is also a watch in popular science that is coated
Kale Posted - Apr 25 2005 : 1:05:03 PM
Diamond is a crystal, so it's not exactly easy to handle.
It's not like glass at all.
yo_tyler Posted - Apr 24 2005 : 11:48:21 PM
1. to melt diamond you will need to make a mini elctric forge. make a small cube with a hollow center out of fire brick. get some carbon electrodes, and a 80amp PSU.(arc welder) put one carbon electrode on each side of the cube, with a small gap between. place the diamond in the gap between the electrodes. attach the welder, and ZZap that diamond. it might work (it will get hot enough, but diamond will burn).
2. why on earth would you want to melt diamond???
3. isn't diamont a little pricey to be melting?
4. thay coat stuff by grinding the diamond into dust, and glueing it.
"I reject to reality and substitute my own" -Adam Savage
BEatonNo1 Posted - Apr 24 2005 : 11:31:19 AM
how do they coat stuff with it then?
Alessandro Posted - Apr 24 2005 : 07:05:59 AM
dimonds won't melt they will sublime, like dryice.
wasssup1990 Posted - Feb 09 2005 : 3:57:22 PM
Ok then Aaron thankyou.
J.C.
Aaron Cake Posted - Feb 09 2005 : 09:27:01 AM
Diamond is just carbon, so it will just burn like anything else.
wasssup1990 Posted - Feb 09 2005 : 05:14:14 AM
Good lord! You're wanting to melt diamond! I've truthfully never heard of that. Why do you wanna do that for? If diamond burns I wouldn't want to be near it. You don't know what to expect. I'm not that good with atoms; could I call diamond high density glass? My imagination is going crazy hear. Maybe it'll pop like pop-corn when burned. LOL
J.C.
BEatonNo1 Posted - Feb 03 2005 : 02:01:35 AM
diamond burns, so youll have to do it in an evacuated chamber depending on its combustion temp.
Chamkeeper Posted - Feb 02 2005 : 11:35:51 AM
A question of purpose comes to mind.
Aaron Cake Posted - Feb 02 2005 : 09:48:15 AM
The sun?
Apparently, a diamond melts at 1687 Kelvin, which is around 2576.93 degrees Fahrenheit. That's not extraordinarily hot. You can get those temperatures out of an oxy-acetylene torch, arc welder, etc.
