 Arc welding dangers
cirvin Posted - Nov 08 2003 : 12:23:16 PM
Can anyone tell me the dangers of arc welding? i know it uses a high temp spark, and the joint will be hot right after you weld, but are their any hidden dangers?
14   L A T E S T    R E P L I E S    (Newest First)
cirvin Posted - Nov 13 2003 : 4:51:56 PM
than k you , i will only weld outside, and use a smal unit for smal things. the site aaron showed me has diagrams and everything for proper welding, an i will probaly take a class and ill bnuold a grill or two for practice
tcd Posted - Nov 13 2003 : 03:43:51 AM
[quote]
HI , I'm a pipe welder so I can answer from 8 yrs. of eperience; eventhough some of the replys seem pretty accurate. FIRST there are five main types of manual welding, so each one has its own unique inherent dangers.
SMAW is the most common welding procedure. so I'll focus on it.
S M A W : (stick welding)
1. the more your body becomes compatible to a large amount of electron flow , the more of a shock you'll recieve. (eg.YOUR CHLOTHES ARE WET and you're are holding the electrode holder and in physical contact with the work (ground).
Make sure your chlothes and gloves are dry.
2.THE LIGHT from welding is said to be ten times brighter than the sun. Since light is VISIBLE RADIATION , as with other forms of intense radiation ,this light is intense enough to burn the outer layer of the eyes and also the retina. So be sure not to look at the welding arc with out eye protection. A # 10 dark lens is good, but I have seen a #13 used in welding hoods; so use what ever is comfortable with in this parameter.
3.Fumes from welding can contain seriously damaging , and health altering chemicals , which over the long term can cause serious health problems. This danger drastically increases while welding on paint,rust,dirt, galvanized steel, oil, etc. TO PROTECT YOUR SELF, under normal circumstances you don't need a respirator. One only needs to : limit time exposed to fumes to only a few hours a day, and weld perferably outside, with the wind blowing the smoke and fumes away from the one who's welding.
4. Welding is a craft, an art, and a coveted skill. Any one attempting to weld needs to know what a quality weld is with intentions of replicating this quality in all work to be done. I know the above statement sounds a bit much... except .. until someone gets hurt because of a faulty weld not holding up due to excessive undercut,lack of fusion,improper welding temperature, porosity, and insufficient penetration. Until you are comfortable and can control these flaws well enough,be skeptical of the weldment until you're sure it'll hold.The responsibility is yours!
BONUS : Welded metal is hot and can cause serious burns . Duhhh. Most alloys exhibit a bright orange or a dark red color after it has been heated to ,or close to it's melting point. however aluminum gives no visual indication of it's temp.You can weld and weld but ,besides the soot left by the exstinguished arc, there's no coloration due to intense heat. So be CAREFUL.!
I HOPE THIS INFO HELPS !
BEatonNo1 Posted - Nov 12 2003 : 8:33:18 PM
well if you stuck the electrodes to a pipe they would just short to the ground
da-g-dog Posted - Nov 12 2003 : 6:58:06 PM
i saw in a movie, the kid hooked a stick welder
up to the water facet, and the guy got a big shock with sparks and everything. obviously not correct
That was probably Home Alone 2: Lost in New York. If the welder was cranked up high enough, you could get quite a shock. But you're right about the sparks, they probably wouldn't happen.
hike master kyle
cirvin Posted - Nov 12 2003 : 6:00:48 PM
Aaron Cake Posted - Nov 12 2003 : 2:54:35 PM
I got myself once in the wet...Most commercial arc-welders have 40V or so at the electrode to help start the arc.
BEatonNo1 Posted - Nov 10 2003 : 11:50:54 PM
well in all the years that I have welded I have never shocked myself, usually you weld with leather gloves...that usually prevents it. Just dont put your toung on the electrodes
cirvin Posted - Nov 10 2003 : 10:52:37 PM
cool thanks. much help. i wil only weld outside probably , so fumes shouldn't be a problem. if you get shocked, is it very dangerous? i expect it shouldn't, i dropped 60 amps a 12v and i just felt enough to let go, but then i did it again.
Aaron Cake Posted - Nov 10 2003 : 09:36:06 AM
Check this out:
http://www.aussieweld.com.au/arcwelding/
BEatonNo1 Posted - Nov 09 2003 : 1:02:53 PM
well your still going to have the fumes when you weld, with a commercial one or not, welding in the open is pretty much you need to do. I think we use NR211 wire (that number sounds about right) it welds over anything, galvanized, painted, powder coated, rusted, wet, ect ect.
Edited by - beatonno1 on Nov 09 2003 1:04:00 PM
da-g-dog Posted - Nov 08 2003 : 6:31:38 PM
mmm fumes. thanx, ill probably use one of the 100$units from harbor freight
You don't neccesarily need a respirator or filter, usually a regular welding hood will be fine. Male sure you have at least a #10 shade lens in it though or you will get flash burn. If you are using 6010, 6011 or 6013 rod for stick welding, they are more dirty than, say, 7018. You also want to make sure you use the right type of rod or wire for the material you are welding. For example, 7018 needs a totally clean and dry weld joint, whereas the 60xx electrodes i mentioned can be run on dirty, rusty or even wet material. Also make sure you know the procedure for each process. 6010 and 6011 for example require a "whipping" action to weld properly, whereas 7018 is just run along the joint. There are several good books out there to learn the basics of welding from. The Welding Bible is a good one. Or better yet, take a class or two at a community or technical college to learn first hand.
hike master kyle
cirvin Posted - Nov 08 2003 : 1:40:02 PM
Kale Posted - Nov 08 2003 : 1:21:33 PM
Be careful in damp conditions. It's harder to control your arc and you're more likely to get zapped. Also, something you cobble together isn't going to have the same kind of safeties built in as a commertial product, so beware of lawsuits is someone else is using it...
BEatonNo1 Posted - Nov 08 2003 : 1:12:05 PM
poor welds can cause your device to fail...um dont breath in the fumes....really dont breath in the fumes if your welding galvanised suff. Oh yeah dont look at it you can burn your retna, but its kinda hard to do in the first place...like looking at the sun
