 Electronics Repair
 My TV doesnt power up
kivdenn Posted - Dec 29 2007 : 06:26:41 AM
Of recent my TV has failed to power on. It has an LED which turns green when it has powered up and it turns red when the TV is turned to standby. But now the LED alternates between Green, as in an attempt to power on, then it turns to Red as in an attempt to go to standby and and it makes a high frequency noise and the process repeats over a thousand times. What could be the problem with my TV? Is it with its power supply? Thanks
Dennis
gagandai555 Posted - Jan 06 2008 : 02:35:54 AM
Actually i'm not too much in electrical stuffs but i guess it's probably because of voltage fluctuation. as MRGONE said that might be because of having deficient on letting voltage through but it might also be because of voltage fluctuation from the power supply itself. do you think your other home appliances also facing the same problem? the best thing you can do is connect your TV through the voltage stablizer that you can buy in a local electric store cheaply and see how it works.
because of you said you bought the TV in second hand imported, i doubt 'bout the voltage specification. because normally we have 110/220V~50/60 Hz power supply but somewhere it's 330V and that might be the factor that your appliance can't withstand the higher voltage. either that input voltage adoptor on your TV might not be working well as MRGONE said.
kivdenn Posted - Jan 02 2008 : 01:13:15 AM
I bought it when it is second hand imported to my country due to the damping tendencies of most business men but it has stayed with me for 2 years. What do you mean by arcs. Thanks
mrgone Posted - Dec 31 2007 : 4:20:14 PM
How old is it? It sounds like the horizontal output voltage. See if the flyback has any arcs around it. Take cover off and fire up and turn lights off in room. You could just have some corrosion not letting the high voltage through.
cyclopsitis Posted - Dec 30 2007 : 12:24:30 AM
I have heard this problem before. It was a REALLY long time ago when I worked at radio shack my friend Dennis had a TV that was doing this exact thing... I'll email him and I hope I can get a quick answer.. I know it might not be the same brand but atleast it will give you a place to start because all TVs are the same the same building blocks just like building a house.
Anyway I'll see if he remembers what was wrong with it.. I know I can't.
