cool_tejinder
Posted - Jan 31 2005 : 06:32:13 AM Hi ppl
I need to measure the diameter of a jet(the one in the carburettor of a vehicle) uptil accuracy of atleast 1/200 of an inch though 1/1000 would be much better. Anyone having any ideas?????
------------------------------------------------------------------- Why ask quetions to which you already know the answers!!!
GMP
Posted - Apr 17 2005 : 03:56:32 AM I have used numeric sized drill bits in the past to determine the jet size. These are very small and if you have a complete set, should give you the increments you want. Just see which size fits in the hole and use them as a "go/no go" gauge.
-Grumpy George
cool_tejinder
Posted - Feb 06 2005 : 10:11:42 PM A jet's holes diameter is less than 1mm in most cases now tell me which caliper has 2 jaws which can fit in a dia of 1mm n then measure uptill accuracy of 1/200 of an inch.
Posted - Jan 31 2005 : 10:06:40 AM A caliper should do fine, as long as it's jawa are small enough to fit the ID of the jet.
