 Turbocharged NA
 s4 or s5 maf
connors14 Posted - Jul 08 2009 : 06:55:29 AM
did you use an s4 maf for your set up Aaron?
it looked like u used an s5 but i wasnt sure
also then a question about when u tuned it
did u just use a/f ratios of what most turbo guys use to tune?
isnt it like 15:1 at idle 14:1 to 3000rpm then 12:1 till redline?
thanks
Aaron Cake Posted - Jul 16 2009 : 09:58:14 AM
S4.
It would be very hard to make a rotary idle at 15:1. The idle becomes unsteady if you start to go leaner then 13.5:1.
13.5:1 is a good place to start at moderate load out of boost. It should be close to 14.7:1 during cruise and then you can use closed loop to lean it out a bit more.
Under boost, 12.5:1 up to a few PSI, then 12:1 until about 5 PSI, then 11.5:1 from that point on.
This page was generated in 0.28 seconds. Snitz Forums 2000
