 Other
 Deadly pens
Nerf Smurf Posted - Apr 06 2005 : 5:21:07 PM
I was bored and found out a way to make a deadly (or VERY painful) weapon using only a regular ball point pen and a rubber band. But i need to ask Mr. Cake can i post it. I might get banned if i do with out permission. So Aaron Can i? Im posting it here because. The weapons is not pnumatic or needs a chamber. This weapons can shoot 6+ stories high.
Binary 1011001101 Posted - Jul 27 2006 : 05:40:46 AM
its a bit of a old topic but ill still post anyway... I made the pen-gun thingy, wow its powerfull!! i its small and fun... at school i shot it into the celing tiles.. its fun!! ;-)
confused251 Posted - Aug 03 2005 : 11:39:28 PM
i have seen a simalar thing done only with the bic pencils and staples it dosent hurt though.
MC BOB Posted - Jun 16 2005 : 11:24:19 PM
G'day y'all. Do you think that both of you guys could build a copy and document ur progress and steps with pics? These sound really interesting. Thanks alot.
Aaron Cake Posted - Apr 08 2005 : 09:52:35 AM
We used a mechanical pencil and a bunch of pen springs. Gut the pencil, and take the long plastic "lead" holder out. This is probably only relevant for Bic pencils.
Get about 4 pen springs, and put them inside the pencil. Now, bend a paper clip to form a release mechanism that loops through the pocket clip and up around where the eraser would normally sit.
To fire, shove the plastic "lead" holder down and slip the release mechanism over. Now pull the "trigger".
Hard to describe without pictures, but you probably get the idea.
Nerf Smurf Posted - Apr 07 2005 : 12:31:54 PM
Well the design i very simple, that I might need pictures. Well get your ball-point pen and take the cap and the point off. You should save the Ink Stick thing. You should have a Plastice tube and the Ink Stick thats inside.
The plastic tube is your "barrel" and the inkstick is your "ammo". But now you need something to propell your ammo. Thats where the rubber band comes in. Now this is the simple part but may be hard to explain.
Wrap the rubberband around eash end of the plastic tube. Now hold the rubber band in the middle of the tube and take the rubber band off of one end. You should have A plastic tube with rubber streched over one open end and the other side of the tube is open. Drop the ink stick inside the open end of the plastic tube and pull back the rubber band along with the ink stick. Aim and let go. I might need pictures for your reference.
Aaron how did you make yours?
Aaron Cake Posted - Apr 07 2005 : 09:38:36 AM
Go ahead. I think I made similar things back in grade 8, but I used springs...
