 Mechanical Things
 Small Engines
Nerf Smurf Posted - May 23 2005 : 10:47:52 PM
Anyone has any instuctions for building a small (within cubic 1ft) engine that can be built at home? That will run using steam or alcohol etc. That could power a small toy boat or a small toy car with a good speed. Or even a rocket engine that can propel a small air craft (about 1-2 pounds).
Oh yea. Happy SUMMER!!!!!!!!!!
Kale Posted - May 25 2005 : 1:39:48 PM
Maybe a small 2-stroke diesel? They've been around for ever. You might be able to scrounge one or at least get the plans and some of the parts from somewhere.
Or if you have access to a junk yard you could gut a turbo unit from a car and try to build your own turbine. There was a guy in Australia that did that. Search for 'jet powered beer cooler'
Edited by - kale on May 25 2005 1:40:44 PM
Aaron Cake Posted - May 24 2005 : 2:44:24 PM
To "build" such an engine, you will need access to a fairly well equipped machine shop. At the minimum, you will need a lathe and a mill.
Rocket engines are a lot easier to build, since you just need to make the outer casing, nozzle and fuel.
cirvin Posted - May 24 2005 : 2:01:05 PM
I had a site with a bunch of small steam engines, but I have long since lost it. It wouldnt be hard, try and adapt pipe fittings for each of the parts. For example, a 1.5" copper pipe could serve as the cylinder.
http://daxter12.topcities.com <Its updated as of 12/9/04, check out the Punk Phone!
