 Mechanical Things
 Model Driller
Nerf Smurf Posted - Jul 17 2003 : 8:21:00 PM
You now me, I like model things that work. Anyone has any ideas for a small Driller. Maybe i'll hit water! if i dont i will drill a deep hole and put a fire cracker in it. I will build a small one that can stay on over night as i sleep and it drill. Maybe i will put it in an antbed and let it drill then put a stick of fire cracker in it. Any ideas
We have the gift to build what we want.
12   L A T E S T    R E P L I E S    (Newest First)
BEatonNo1 Posted - Jul 29 2003 : 02:58:54 AM
maybe, but they shure do get the job done ...works wonders on old stumps
Chamkeeper Posted - Jul 29 2003 : 01:35:00 AM
If you learn your Chemistry, you'll find Diesel and Fertilizer make cheap sloopy explosives...
No more to follow so please don't ask.
BEatonNo1 Posted - Jul 18 2003 : 2:02:32 PM
yeah you have to be really carefull with the stuff. its the same stuff that was used in the oklahoma city bombing...
Nerf Smurf Posted - Jul 18 2003 : 10:51:39 AM
thanx you 2
Aaron Cake Posted - Jul 18 2003 : 10:07:11 AM
It goes without saying that burying any explosive in the ground is very dangerous. And don't underestimate the power of diesel and fertilizer. HUGE power. You could end up blowing a crater in half your block.
BEatonNo1 Posted - Jul 18 2003 : 01:03:40 AM
if you want to blow something up all you need is some chemical fertilizer, diesel, and newspaper. make shure you have enought time to get about 100yards away behind a metal plate about 2" thick before it goes off...
Nerf Smurf Posted - Jul 18 2003 : 12:47:38 AM
i wont burry it
BEatonNo1 Posted - Jul 17 2003 : 11:15:50 PM
Well you must live next to the coast...our neighborhood well is around 1000 ft deep once you get past our first foot of soil you hit limestone... youd probly have to replace the bit every 25 ft... as for the fire CRACKER what difference does it make, it still need O2 to burn
Nerf Smurf Posted - Jul 17 2003 : 10:41:23 PM
No a fire CRACKER not a fire work thing
fire crackers dont go in the air they are like small sticks of dynomite. Under ground "Water Tables" are just a few feet under the soil. Its not fully water in some areas, but mud like.
Edited by - Nerf Smurf on Jul 17 2003 10:47:11 PM
BEatonNo1 Posted - Jul 17 2003 : 10:25:25 PM
do you realize how deep you have to drill to reach water...you could have a hard time using a power drill wich would also have a hard time drilling through rock, but i guess it would be possible...as for using a firecracker, you really wont get much of a response because it would be hard for the firework to get air
Nerf Smurf Posted - Jul 17 2003 : 10:12:11 PM
thanx but i need sominthin smaller
BEatonNo1 Posted - Jul 17 2003 : 9:21:41 PM
there is a small comerciall one that has a lawnmower engine (vertical shaft) underneath a tripod .... anyways unless you live along the cost where there is mainly a sand undersoil, drill heads are expensive
