 Spudguns
 Pneumatic Guns
 Getting Low Range @ 100psi
n/a Posted - Feb 26 2004 : 2:01:52 PM
I have 2 very powerful pneumatic, but for some reason they lack substantial range. Powerful at short distances but weak after aprox ~ 200ft. Main ammunition potatoes. Can break plywood at short range.
1st gun: 2 in diameter barrel 5 ft long, dual solenoid with 2 air chambers made from 2 in @ 6ft (inter connecting).
2nd gun: 1.5 in diameter rifled barrel 4ft long, single solenoid with 2 air chambers made from 2 in @ 5 ft (interconnecting).
Suggestions to boost power.
n/a Posted - Mar 03 2004 : 2:23:54 PM
You could try on you next spud gun to make your compresion chamber atleast 1.5 in. larger then your barrel, and try to make your valve around the same size as your barrel. Even about an inch smaller would work. But using a reducer would speed up the velocity of the air entering the barrel. Also make sure the barrel is long enough, and you are pumping it to a high enough psi. I use from 80 to 120 psi. on mine.
Edited by - Joeman on Mar 03 2004 2:24:58 PM
BEatonNo1 Posted - Feb 26 2004 : 6:42:54 PM
just because you have high psi doesnt nessicarily mean more range. you want to be able to get all of the air in the chamber behind the spud as quickly as possible. using a valve with the same diameter as your chamber will alow you to get the most volume behind your spud
da-g-dog Posted - Feb 26 2004 : 2:21:21 PM
More pressure. If your pipe is Schedule 40, it shoud be able to handle 250 psi.
hike master kyle
