 Turbocharged NA
 spectre ems pro 13b 6 port
Author  Topic Next Topic
rotorkoko
Posted - Mar 21 2013 :  7:43:39 PM  Show Profile  Reply with Quote
i have 1988 mazda FC3S with an 86 6 port motor. the motor is setup in n/a fashion at the moment, but turbo is in the future once the base tune runs well and i feel comfortable with the tuning procsess. i have the pineapple racing sleeve inserts, premix, with a wrapover intake for a DCOE style setup. im running a Jenvey twin 50mm itb with 2 injectors.(4 injectors total 440cc/each) im running the Spectre EMS Pro with a MSD DIS4 box, 2 MSD 8232 secondary coils and one MSD 8204 dual tower blaster coil for the primary. i chose the FAST dual wideband O2 im using the stock CAS for now with one sensor hooked up and a modified trigger wheel (12 minus 2 teeth). the car will start and run rough, but usually falls on its face after a few seconds. i can coax it alive and it idles at 650-900 rpm. the whole thing starts to break up around 4000 rpm ive been at this for about 3 years now and ive realized that i need a little help. anyone have any insight, it will be greatly appreciated
   Topic Next Topic
