2261 Posts |
Posted - Jan 14 2012 : 08:08:41 AM
If both inverters have the same power conversion efficiency at your load (80 watts), then they will both drain the battery at the same rate.
If your inverter comes with a datasheet/manual, it may have a graph that shows you the efficiency of the inverter at different power output levels. That's how you can determine which inverter will best make use of your battery. |
