 Computers/Electronics
 USB contraption
Page: of 4
codingplanet
Posted - May 24 2011 :  6:01:15 PM  Show Profile  Visit codingplanet's Homepage  Reply with Quote
I started making a USB contraption that would report temperatures and voltages to a PC and also alter fan speeds with PWM. It's my first time using a PIC 18F and also my first time working with USB but it's gone well so far.
Temperatures will be read with thermocouples but I've yet to arrange the hardware to interface them to the PIC. I've done it before with a 16F + LCD but I used an all-in-one chip that costs about £20 each. This time I think I will implement coldpoint compensation and such myself along with an instrumentation amplifier for the main amplification. Something I've yet to think about properly.
The firmware was written with Microchip's C18 and is based off one of Microchip's HID examples. The software is written from scratch by me using VB.net.
The reason behind this is that I have 2 very high speed fans (rated at 3A, 190CFM) on the radiator in my watercooling setup and I would like to run them at a lower speed most of the time but be able to ramp them up when needed.
Also when I'm benching with LN2, sometimes 2 temp meters and 4 voltmeters are needed and the desk gets a little cramped :P This would also give me the ability to log the data if I wanted to.
Thread can be found on my site here: http://www.benchtec.co.uk/forums/threads/8170-Owl-s-Contraptions
Posted - May 24 2011 :  10:47:03 PM  Show Profile  Visit wasssup1990's Homepage  Reply with Quote
Cool little contraption you've got there.
codingplanet
Posted - May 25 2011 :  04:46:40 AM  Show Profile  Visit codingplanet's Homepage  Reply with Quote
Thanks Johnny. I wonder if anyone here can recommend me a fast switching diode to clamp the back emf? I was using a 1N4001 when I had a fan connected and it was getting warm (not hot), but I guess it wasn't fully switching on during the low period of the PWM pulse.
And can someone tell me how I would go about defining the specs of such a flyback diode? Such as how do I know how fast I need it to switch? Should I just choose the switching time to be a lot smaller than the minimum PWM low period that I could have? And what current rating do I need to use.
The PWM switching is done using a MOSFET from the PIC pin. Load is a 3A rated fan, continuous current is measured to be under 2.5A, I don't know what the surge current could be. PWM frequency is 30KHz.
Posted - May 25 2011 :  08:54:17 AM  Show Profile  Visit wasssup1990's Homepage  Reply with Quote
The 1N4001 is just a low spec general purpose diode. It isn't suitable for high speed applications.
http://www.aaroncake.net/forum/topic.asp?TOPIC_ID=8771
A Schottky diode practically doesn't have any reverse recovery time. Their forward forward voltage drop is usually higher than their "Ultra Fast" and standard Si diode counterparts though.
codingplanet
Posted - May 25 2011 :  12:29:22 PM  Show Profile  Visit codingplanet's Homepage  Reply with Quote
I realise the nature and unsuitability of the 1N4001, I just used it because I have lots of them. The only other diodes I have are 1N4148 wish I guess would be worse given their much lower current rating (albeit faster switching).
Forward voltage drop should not concern me though right? As I am using it only as a flyback diode.
Do you suggest that I use a Schottky diode then? Should I take care of it's reverse recovery time? Or can it be ignored as you said it "practically doesn't have any reverse recovery time"?
Thanks
Posted - May 25 2011 :  8:12:10 PM  Show Profile  Visit wasssup1990's Homepage  Reply with Quote
Can you quickely draw up a schematic?
codingplanet
Posted - May 26 2011 :  08:18:40 AM  Show Profile  Visit codingplanet's Homepage  Reply with Quote
Sure. I couldn't find a motor so I put an inductor there instead.
http://i547.photobucket.com/albums/hh471/UnknownReactionz/pwm.png?t=1306412447
Posted - May 27 2011 :  03:34:02 AM  Show Profile  Visit wasssup1990's Homepage  Reply with Quote
Just looking at datasheets I can deduce:
1) At least put a small heatsink on your MOSFET.
2) Your rise and fall times on the gate appear to be adequate, with assumptions.
3) Good to see a gate sinking resistor. Resistor value is adequate.
4) MOSFET is suitable for load.
5) You may be cutting a little fine with a VGS(th) max of 4V, assuming a signal of 0-5V. Logic-Level MOSFET recommended if that's the case.
6*) Your flyback diode is inadequate. Reason: trr parameter is too large (or isn't specified).
*Solution:
Choose a Schottky, or Silicon Carbide Schottky rectifying diode. Other specifications should be easy to decide such as VF, VR, IF and IFpeak(repetitive). Choose a diode with a VR >= 15V and a VF as small as possible. IF(max) doesn't have to be huge; you may be able to get away with 100mA. 500mA may be enough for IFpeak(repetitive).
Good luck.
codingplanet
Posted - May 27 2011 :  06:24:34 AM  Show Profile  Visit codingplanet's Homepage  Reply with Quote
Thanks very much Johnny. I'm off to the meet soon, but I will do some diode hunting when I get back :)
http://www.benchtec.co.uk/forums/threads/8227-Benchtec-s-Spring-LN2-meeting-The-Batcave
Posted - May 27 2011 :  10:13:00 AM  Show Profile  Visit wasssup1990's Homepage  Reply with Quote
You're welcome. It looks like you take this over-clocking thing pretty seriously.
codingplanet
Posted - Jun 01 2011 :  09:02:24 AM  Show Profile  Visit codingplanet's Homepage  Reply with Quote
Is something like this a good choice Johnny? http://uk.farnell.com/taiwan-semiconductor/b0540w/diode-rectif-40v-0-5a-sod123/dp/1863143
Posted - Jun 01 2011 :  09:07:06 AM  Show Profile  Visit wasssup1990's Homepage  Reply with Quote
Well done.
codingplanet
Posted - Jun 01 2011 :  09:32:13 AM  Show Profile  Visit codingplanet's Homepage  Reply with Quote
lol that sounded rather sarcastic. The back emf only generates a small current then? I was told elsewhere to use a diode rated for 6A continuous current as my fan is 3A rated.
codingplanet
Posted - Jun 01 2011 :  09:43:17 AM  Show Profile  Visit codingplanet's Homepage  Reply with Quote
Would this one be better? http://uk.farnell.com/taiwan-semiconductor/b0520lw/diode-rectif-20v-0-5a-sod123/dp/1863141
Lower reverse breakdown voltage and lower forward voltage.
Posted - Jun 01 2011 :  10:42:09 AM  Show Profile  Visit wasssup1990's Homepage  Reply with Quote
The back EMF generates a high current through the diode but only for a very short amount of time (a spike). The purpose of the diode is to clamp the spike to prevent potential damage to other circuit components (this is critical in a computer).
You are not going to get 6A of continues current, you are only going to get a small fraction of that if you take the average back EMF current through the diode over time. So yes, over time the average continues current that flows through the diode is small. The current that will be operating your fan is obviously not going through the diode so the 6A continues forward current spec is overkill. The repetitive peak forward current is what's more important to your application.
I know the repetitive peak forward current isn't specified in the datasheet but a "Non-Repetitive Peak Forward Surge Current" as the datasheet puts it, of 5.5A is a good indication that this diode will handle the back EMF without a sweat.
Yes that one would still work just fine. The reason why I said "Choose a diode with a VR >= 15V" is so you could have some headroom above your 12V supply, but 14V is still enough.
I hope this clears things up for you.
Ah! I'm so busy.
I've got an assignment due in a few hours which I am submitting now and after that I have to give a presentation in Artificial Intelligence. Then over the next few weeks I would have completed a grand total of 14.5 hours worth of exams. Fcuk me!
Edited by - wasssup1990 on Jun 01 2011 10:54:04 AM
codingplanet
Posted - Jun 01 2011 :  10:55:46 AM  Show Profile  Visit codingplanet's Homepage  Reply with Quote
Thanks a lot for the help Johnny. I'll go for the one with higher VR.
Page: of 4 Previous Topic Topic Next Topic
