 Turbocharged NA
 Turbo Potential
JC6711
Posted - Nov 10 2010 :  09:44:45 AM  Show Profile  Reply with Quote
Whats the potential of the stock turbo on a S4 turbo 6 port. Plans are to run a big front mount, 555s, SAFC. Im wondering what the max power you can get with them, because they are so cheap i was thinking of going this way instead of a full custom manifold and somesort of used large turbo(from a diesel or something). Looking for 300whp-350. Thanks
Edited by - JC6711 on Nov 10 2010 09:46:04 AM
Posted - Nov 11 2010 :  1:54:15 PM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
About 275HP when extremely well tuned. Meaning that in order to that get that level of power, an S-AFC won't cut it.
Realistically, about 250HP at the most with just using an S-AFC and larger injectors because you will have to dump fuel to avoid detonation as the NA ECU advances timing.
JC6711
Posted - Nov 11 2010 :  2:32:42 PM  Show Profile  Reply with Quote
Hmmm alright. Im not gonna be able to afford a standalone. Would upgrading to 750cc or 1000cc secondaries help? Also is it better to run the T2 ECU or N/A in regards to timing? If i wanted to reach those goals what would you recomend for turbocharger size then?
Posted - Nov 13 2010 :  10:44:51 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
Increasing injector size would make the prolem worse.
If you run a TII ECU, you can tune fuel a bit better becuase the TII ECU at least knows what to do with timing. To run the TII ECU you will need the TII pressure sensor and the TII AFM as well. It plugs into the NA harness with minor changes.
If money is tight, then look into an RTek. It is a programmable stock ECU.
As for the turbo, look into a BNR Stage 1 hybrid stock turbo. That will allow you to retain the stock exhaust manifold.
http://gonzaloherrero.com/bnr/index.php?option=com_content&task=view&id=67&Itemid=89
JC6711
Posted - Nov 14 2010 :  11:19:14 AM  Show Profile  Reply with Quote
So the stock TII ecu will adjust timing acording to boost?
Posted - Nov 16 2010 :  10:50:17 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
Yes. But to run larger injectors you will still need a piggyback, so I'd suggest just going with the RTek.
JC6711
Posted - Nov 17 2010 :  09:01:19 AM  Show Profile  Reply with Quote
So a rtek 1.7 with 720cc and a safc would be a decent setup along with the T2 ecu?
Posted - Nov 20 2010 :  10:24:34 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
I'd recommend the stage 2, which is something you can actually tune yourself. Yes, 550CC primaries and 720CC secondaries should be enough for about 300HP. But because the RTek is ultimately based on the stock ECU, I can't say for sure. A full standalone can drive injectors harder than the stock ECU.
