JUAN DELA CRUZ
476 Posts |
Posted - Sep 03 2010 : 06:22:47 AM
Hi, Are you referring to the Automatic battery charger?
I think higher wattage transformer is better as long as they have the same primary and secondary voltage required by the circuit.
It uses D.C. pulses, so bridge diode is not applicable.
I hope it helps you out. |
juan dela cruz Penniless INVENTOR |
