 Sound/Radio
 Cheap / Low power Freq. Counter
mrgone
Posted - Feb 04 2010 :  7:14:22 PM  Show Profile  Reply with Quote
I worked this up for a display for a radio device so just wanted something cheap and simple with low power consumption:
Download Attachment: 1KHz-100Hz-Res.gif
60.47 KB
I cannot post pictures of it so I put them over here:
http://www.electro-tech-online.com/general-electronics-chat/103299-cheap-low-power-simple-freq-counter.html#post841912
It's really simple. I hand wired it together using about 32 gauge strap wire. The switch SW1 will shift the whole display to the right so that you can read down to the 100Hz position on the LCD. Then if you need to read a frequencie higher than 9.9999 MHz you switch it back to view the upper digit.
