 120VAC to 24VDC 325 AMPS
afghanman2009
Posted - Sep 04 2009 :  03:09:20 AM  Show Profile  Click to see afghanman2009's MSN Messenger address  Reply with Quote
Currently I work with the Military in Afghanistan. The program I'm on requires me to REBUILD blown up IED ROLLERS. Part of the rebuild is testing the Hydraulic system which intells operating the hydraulic system. It is electricly operated 24VDC. What I need is some guidance on where to purchase parts and how to build it myself or a source where I can purchase it already built. It will be powered by 110-120VAC 60HZ and converted to 24 VDC 325 AMPS draw max. The System has a 325 AMP Fuse Link within the system. I also need to include a fuse in my system if I build it from scratch. The company I work for has to go through alot of RED TAPE to do this themselves. I have taken the first step to cut through the red tape and keep our boys safe.................Thanks for the input.
Afghanman2009
Walter
Posted - Sep 06 2009 :  6:00:58 PM  Show Profile  Reply with Quote
Are you sure is THREE HUNDRED and TWENTY FIVE (325) AMPS???
Posted - Sep 07 2009 :  10:25:34 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
The short and simple answer is that it's not going to happen. Designing an inverter of 7800W is nontrivial.
