 Turbocharged NA
 Modifying the NA LIM
rx7dude822
Posted - Sep 09 2008 :  08:38:36 AM  Show Profile  Reply with Quote
Hi Aaron,
Is it the ACV part that interferes with the Turbo? If I were to cut that part out and patch it up would I be able to mount the turbo using the stock turbo manifold?
Thanks
Posted - Sep 09 2008 :  10:05:40 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
Even if you shave the lower NA intake manifold completely, there is still not enough room to mount the turbo without a spacer.
Either make a spacer to go between the manifold and turbo, engine and manifold, or make your own manifold.
You can also modify the TII lower intake to fit the NA block, which necessitates going to the TII upper as well.
rx7dude822
Posted - Sep 09 2008 :  1:52:54 PM  Show Profile  Reply with Quote
Thanks Aaron!
rx7dude822
Posted - Sep 09 2008 :  3:53:50 PM  Show Profile  Reply with Quote
Is it possible to adapt the Turbo LIM to the N/A UIM? I would want to keep most of the N/A parts.
Thanks
Posted - Sep 10 2008 :  5:15:52 PM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
No, not easily at all. The NA intake is much larger. The upper intake is designed to bolt to the NA lower which sits basically at the level of the top of the engine. The TII lower sticks up 6" further.
