 lawnmower go-kart
02matada
Posted - Oct 10 2005 :  2:44:43 PM  Show Profile  Reply with Quote
my dad bought me ride on lawnmower for £20(about $40) because the man said he couldnt get it working we got it real cheap. we fixed the engine in a few mins but id like to ask, how could i change the gearing to reach a higher speed?
Posted - Oct 11 2005 :  08:58:34 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
Depends on the transmission used. If it's just sprockets or pulleys, swap them. If it's a hydrostatic transmission, then I have no idea.
Kale
Posted - Oct 11 2005 :  2:29:09 PM  Show Profile  Visit Kale's Homepage  Send Kale an ICQ Message  Reply with Quote
Maybe post some pictures? That would help the gearheads see what you've got.
02matada
Posted - Oct 11 2005 :  2:52:40 PM  Show Profile  Reply with Quote
thanks but ive found out how to speed it up, were contacting a lawnmower specialist and were going to find a bigger sprocket for the gearbox. as the sprocket for the gearbox is about 10 times smaller than that of the axle so a lot of speed is lost as a result
robertdjung
Posted - Aug 02 2006 :  03:20:00 AM  Show Profile  Visit robertdjung's Homepage  Reply with Quote
you just can't use a lawnmower engine for a go kart. lawnmowers are vertical, go karts are horizontal. You've either got to use a spider gear to change the direction of the force, or some goofy belt system that will wear out quick, or turn the engine on it's side, which doesn't work.
I've got more info about it at http://www.diygokarts.com/engine/can-you-use-lawnmower-engine.html
Posted - Aug 02 2006 :  10:01:04 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
You can turn the engine onto it's side with some modifications...I think I've posted the procedure before so a search for "convert horizontal vertical" should turn it up.
marks256
Posted - Aug 02 2006 :  12:28:04 PM  Show Profile  Reply with Quote
You are saying that that can actually be done! Oooh! That is awesome! I have a 12hp Briggs that is virtcal, but still runs perfect! I'm thinking my scooter will go faster now....
Knowledge is a dangerous weapon that humans should not be trusted with.
Posted - Aug 04 2006 :  09:32:18 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
I've done the vertical to horizontal conversion before and it works well. But it does require some of the parts from the horizontal engine to make it work, and it's not "plug and play". A 12HP Briggs should already have a cast iron flywheel but an engine that big might have a pressurized oil system which will be a LOT harder to convert.
marks256
Posted - Aug 04 2006 :  12:22:24 PM  Show Profile  Reply with Quote
I'm not sure it does. I will check later. Oooh! The possibilities!
