 Mechanical Things
 Making a mulcher
Posted - Mar 15 2003 :  09:57:29 AM  Show Profile  Reply with Quote
Hi,
I want to make a mulcher.
Probably using an electric motor.
Please tell me more about the one
you made before.
Like how far down is the blade?
Is it a normal lawnmower blade?
John.
Posted - Mar 15 2003 :  10:49:31 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
The blade is bolted directly to the engine, exactly how it would have been in a stock lawnmower configuration. It is a standard mulching lawnmower blade.
Posted - Mar 15 2003 :  11:21:04 PM  Show Profile  Reply with Quote
Thanks for replying so soon.
I doubt if i will be using an engine,
i intend to use an electric motor.
The arrangement looks simple enough,
if it doesnt 'stir' it up enough
i suppose i could shovel it back in the top.
I assume you shouldn't let it get too full
or it wont work ?
John
Posted - Mar 16 2003 :  12:03:36 PM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
I normally use it until it fills up enough to stall. Though I doubt it would be very easy to stall a torquey electric motor.
Posted - Mar 21 2003 :  6:04:04 PM  Show Profile  Reply with Quote
I will be putting this together over the next few months,
i'll come back and let you know how i get on.
It will be a 'synchronous' type motor, with a capacitor
start, arranged just as you have arranged the engine.
I dont know what a mulching blade is, i guess its got
fan like make up to stir it all up.
The end of a fity gallon drum about a foot deep will
be the main chamber. If thats too big or too deep
i'll have to find something else.
Cheers, John
Posted - Mar 22 2003 :  2:08:38 PM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
The drum would work great.
The "muching blade" is normally sold by almost any lawn care or yard store. It is a blade designed to be bolted in place of a standard lawnmower blade so you can plug up the grass chute and mulch while you mow. They work very well, and eliminate all raking. They guys/gals as the parts counter would know what you mean.
cirvin
Posted - Nov 05 2003 :  9:48:09 PM  Show Profile  Send cirvin an AOL message  Reply with Quote
cannibalize an elecric lawnmower
kenmce
Member
Posted - Nov 15 2003 :  10:04:46 AM  Show Profile  Reply with Quote
[quote]
I will be putting this together over the next few months,i'll come back and let you know how i get on.
(/quote)
I would like to suggest that you have two "slap switches" on opposite side of the machine so that if it jams or there is a problem, you can just smack the switch and turn it off in a hurry. Red is the traditional color for such a switch.
(quote)
I dont know what a mulching blade is, i guess its got a fan like make up to stir it all up.
(/quote)
A "mulching" blade is kind of like what you guessed. It's shape is tweaked so that it will will make a breeze to pick up the grass repeatedly and have another chance to slice it each time.
(quote)
The end of a fity gallon drum about a foot deep will be the main chamber. If thats too big or too deep i'll have to find something else.
(/quote)
Put your assembly up at the top of the can, not the bottom. That way you can chop 55 gallons at a time and not have to stop and empty it all the time.
If you want to get fancy you could have secondary choppers above or below the blade so you have the chance to chop it twice as it falls in. A pair of counter-rotating blades would have a high geek pride factor, or even just wire rods or chains like heavy duty weed eaters.
I would like to reccommend you build in some kind of anti-kickback door so that pebbles and bits of twigs don't come shooting back out at you at a hundred miles an hour, that gets old real fast.
I would also also suggest you design it so that no one can reach in and touch the blade while it's working. A shredder is a great machine to have around, you should make it safe enough that you could lend it to somebody and not have to worry about them.
Posted - Nov 17 2003 :  9:47:45 PM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
Yes, anti-kickback is a very good idea. Trust me on this. My mulcher will throw debris 30 feet into the air. As for a method to prevent dismemberment, the long chute on my design basically serves that purpose. Would take LONG arms to reach the blades.
