 Need 12v led delay circuit
Posted - Dec 09 2003 :  11:33:14 AM  Show Profile  Reply with Quote
I need a simple electronic delay circuit for making 2-12v LED tailights blink sequentially. A mechnical flasher supplies the initial 12v to LED #1. This also supplies power to a SCR (?) with a r/c (?) timing circuit on the gate. A pot would be the best to determine desired delay. The cap charges up & fires the SCR & I'm just guessing 30--100 ms after first light comes on 2nd light comes on. Mechnical flasher then breaks circuit & both go off. Any body have a quick circuit? The LED's are the multiple "truck" style with 5-25 LED's in housing. I do not know amperage.
Thnx, Mike
YS
Posted - Dec 14 2003 :  8:02:06 PM  Show Profile  Visit YS's Homepage  Reply with Quote
Mike, you described your schematic pretty well. Actually you already had designed it. Connect power to resistor, resistor to pot, pot to cap, cap to ground. You need extra resistor to limit the minimum value of the pot. The Pot/Cap connection point could be connected to SCR gate directly but it is better to have some sort of triggering device. As you have 12V power, you can try CMOS gate with Shmitt trigger. There is a chip with 6 Smitt trigger inverters. Choose CMOS series which can handle 12V. connect inverter input to RC, and inverter output to other five inputs; other five outputs connect via 300 Ohm (or about that) resistor to SCR gate. So, you will have 5 inverters in parallel, which is allowed if they are on the same chip.
As for delay, calculate approx. time value as T = RC.
