 Turbocharged NA
 SAFC Settings
Posted - Sep 15 2003 :  10:14:05 PM  Show Profile  Reply with Quote
I have just gotten my Turbo'd N/a running ^_^ (thnx for the almost complete guide aaron!) I was hoping those who have already done the mod could share some SAFC settings that might work (or a general area) for the time being before I go get it dyno tuned. Thanks!
Posted - Sep 16 2003 :  07:29:11 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
Depends on your fuel setup. Need more information to make some guesses.
Posted - Sep 16 2003 :  4:37:04 PM  Show Profile  Reply with Quote
Ok, well I have a walbro 255 fuel pump with stock TII injectors on primary and seconary.
Posted - Sep 17 2003 :  09:23:31 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
Well, I was able to go -30% at idle, slowly tapering up to 0% at 3500RPM, then increasing 5% for every 1000 RPM. This was very rich, but fairly safe. If you have a dyno and a wideband, you can tune it properly. I am speaking of the high-throttle map. For the low throttle map, you'll be negatives all the way, probably -30 to -25.
Posted - Sep 17 2003 :  10:05:33 AM  Show Profile  Reply with Quote
ok sounds good ^_^ thanks so much!
Posted - Sep 17 2003 :  11:11:19 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
Any pictures and stuff on your project?
Posted - Sep 17 2003 :  7:47:56 PM  Show Profile  Reply with Quote
not yet, bu thopefully soon.. but hopefully soon... its not as nice as yours htough, I dunno how to weld so I had to make due with coupling and some marine rad hose which was flexible.
Posted - Sep 17 2003 :  7:49:51 PM  Show Profile  Reply with Quote
also I have a s4 so the throttle for hi is set at 99% and low is 97%, would i still be able to use -30 to -25 all the way through on the low map?
Edited by - Z3r0 on Sep 17 2003 7:50:22 PM
Posted - Sep 18 2003 :  09:49:36 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
Yes, those settings will be fine. The S-AFC on the S4 is always a little weird. If you want, you can connect the full range TPS from the S5 so you have finer control.
Posted - Sep 29 2003 :  7:53:29 PM  Show Profile  Reply with Quote
hopefully I can get a better camera and take some real pictures ^_^
hondakiller
Posted - Jan 07 2004 :  6:46:16 PM  Show Profile  Reply with Quote
or you could use the boost sensor instead of the TPS
