 inventory program
ecm Posted - Oct 27 2003 : 6:34:55 PM
Hi Im Looking for a program to keep inventory of my electronic parts or any ideas. looking for input here or what you do for your parts inventory.
to do or not to do
ecm Posted - Dec 04 2003 : 5:42:34 PM
Thanx for the tip and as for Access I dont have that program ,I will look into it to see how much it cost .
to do or not to do
n/a Posted - Dec 03 2003 : 10:43:36 PM
ECM. If you have your stock represented in lists, you can do an "Autofilter" of the columns that you have established. Just select the entire column by clicking on the column name/header "A, B, C etc." then go to the tools menu, select "filter" then select "autofilter". This will produce a drop down arrow, which will list all of the items in that column.
Another method is to do a simple "Find". press Ctrl + F. Then enter the item you are looking for. Excel will find the first item that matches your description. To find more, hit "find next" and excel will find the next in series. You can also use wildcard "*" for unknowns. For instance, if you're looking for a 555 timer, but you have all of the IC's listed by part number, you can use "* 555" etc. Play around with it.
I have created an Access database that I use to categorize my parts. If you're interested in the copy, send me an email and I'll shoot it over to you. Johnson7777 at hotmail dot com. Replace at with @, dot with .
Aaron Cake Posted - Nov 10 2003 : 09:31:06 AM
Google - > Microsoft Access
Part of office. It's the database program.
ecm Posted - Nov 07 2003 : 7:44:33 PM
I know that . the thing is if i need a 4017 how do i get excell to display stock without going thru the item list . is there a way of to get excell to find that item by just entering the part number. Aaron Im not familiar with Access wich program is that.
to do or not to do
Aaron Cake Posted - Oct 28 2003 : 09:22:02 AM
Access has a built in inventory thingie. Seems to work well.
Nerf Smurf Posted - Oct 27 2003 : 10:55:17 PM
Microsoft Excell is great for listing your components.
