Posted - Oct 13 2009 : 3:23:06 PM I am trying to make a circuit which will do the following. If the circuit has voltage applied to it (like 3 volts) then the LED will light up for 2 seconds and then shutoff until the voltage is removed and then re-applied. Similar to how a car remote works. If I hold in the button to unlock the doors, it doesn't keep unlocking, just one time until I let off and then re-press it. I can figure out the timer part but not the part that would not reset the relay only when voltage has been removed. I am sure there is an easy way to do it but I have limited experience.
KMoffett
Posted - Oct 14 2009 : 3:26:30 PM From your description you need a "monostable" multivibrator circuit. http://home.cogeco.ca/~rpaisley4/LM555.html#29 Circuit #1, but replace the two diodes and relay on pin-3 with a resistor and LED. Are you locked-in to a 3V supply for the circuit? Where does the "relay" fit in your concept?
