 Computer power supply mod
yodi Posted - Jun 05 2009 : 3:40:56 PM
Im an electrician trying to convert a Computer power supply for working with simple circuits. The power supply I have does not have a switch. It does have a momentary test switch. I would like to switch the power on from a Power strip. I know I need a load resistor to keep the power on. I have a grey,green,black and purple going to the test switch. I have two mauve looking wires which one is smaller than the other. The larger one went to the motherboard connector itself. I have a power resistor for the load and an led on light and 330 ohm resistors. I would like to know how to wire this up in order to keep the power on. I also planned on using a 1 amp fuse. I assume this goes to the powers hot leg and then to a black. The fuse holder I have is a 250vac/10amp.
Thanks!!
Aaron Cake Posted - Jun 13 2009 : 10:52:34 AM
This may help you:
http://www.wikihow.com/Convert-a-Computer-ATX-Power-Supply-to-a-Lab-Power-Supply
