 Basic digital volt meter/ ammeter
autoassault Posted - Jun 04 2009 : 03:37:07 AM
I would like to build myself a little car alternator testbench. Basically a motor to run the alternator, by belt. A warning lamp,as on the dash, to show if charging or not, a volt meter to show the carging rate, an ammeter to show the charging current and a 12v as my load. What sort of variable load can i have to do load tests and can i put together two basic digital displays for the volt and amps with maybe 1 inc display? Nithing fancy, would like to keep it as basic as possible. Any advice would be appreciated.
Aaron Cake Posted - Jun 13 2009 : 10:54:31 AM
Probably the easiest load are several low value high wattage resistors that you switch into the circuit.
Commercial battery testers use large carbon resistors for this. Yours might be as simple as a specific gauge of wire in a bucket of water.
