Mysticle31
Posted - Oct 14 2007 : 3:04:34 PM Hello again
I have a car with a sunroof. I've already got one touch operation on the sunroof working on all three "positions". The sunroof has three "positions". Starting with the roof open, if I tap closed it will close. If I tap close again it will vent. If I tap close when vented nothing happens. If I tap open when vented the sunroof closes vent.
I have a couple modules that roll up the windows when I lock the car. However, I can't run them on the sunroof because if the sunroof is closed and I lock the car, the sunroof will vent. Is there a simple circuit that I can use to connect the sunroof to the auto-close system only if the roof has been opened? Or make it so the roof closes when I turn of the ignition only if the roof has been opened. I like the latter option better.
