 12 volt delay circuit/relay
n/a Posted - Aug 02 2003 : 2:38:36 PM
I am trying to find/build a circuit to operate a relay on my motorcycle that will
activate (start delay) when the ignition switch (12 Volts) is turned on. I want the circuit to activate the relay after a pre-set amount of time and to completly shut off when power (ignition switch) is turned off.
What I need is the circuit to operate a lighting relay I currently have,so the lights will only come on after the motorcycle is started. The purpose is to limit the amps used at start up.
Any suggestions?
Aaron Cake Posted - Aug 04 2003 : 3:01:32 PM
http://www.aaroncake.net/circuits/relaytim.htm
