 Turbocharged NA
 88 RX7 Turbo Conversion Problems
Tubro Monster Posted - Dec 12 2005 : 12:57:39 AM
I've reciently completed converting my 88 rx7 N/A to a T4 Garret (AR 90) using your Almost complete guide. When I start my car it wants to start and its stumbling on itself but is shooting fuel from the turbo exhaust and smokes.. I upgraded both injectors (first and secondary) but not sure if I was only suppose to upgrade one of the two. They are both injectors and fuel pump are off a turbo II. I have not changed my ECU or wiring harness, because I wasnt sure if i was suppose to. Nor have I installed a SAFC. Any input or suggestions would be very helpful. I will send photos when project is complete. ASAP
Aaron Cake Posted - Dec 13 2005 : 09:38:57 AM
Sounds a lot like one of the injectors is stuck open. It's rare, but it does happen. You can confirm by removing the upper intake with the injectors still connected, then power on the car. If you get fuel shooting out of them, or can hear fuel shooting out of the primaries, then that is the cause.
If the injectors are fine, you will have to start troubleshooting .Vacuum leaks? Fouled plugs or ignition problem? Vacuum line to FPR?
