Binary 1011001101
Posted - Apr 01 2007 : 12:27:21 PM So I wanted to make a variable inductor for a speaker crossover, once was wound the it looked like a secondary for a tesla coil, at the some time I was fiddling aroud with a flyback. So long story short, made it into a tesla coil after a long time, then slung the lot in a box. And ive now got a tesla coil!! The output is a little purple haze around the wire, it don't work with a topload, definitely no streamers :-(
The specs are: Unknown turns secondary Unknown wire guage Unknown output voltage Unknown flyback output Unknown MMC bank value Unknown operating frequancy Unknown power input/output But I do know: Based on a 555 timer 4 turns primary Flyback as HV transformer capacitors are fed a lot more voltage than rated Gets very hot Static spark gap Total cost: £0.00
What do you think of it? Can I touch the output safely and draw sparks from my fingers? I made this with no calculations I am amazed and so so happy that it worked.
5 L A T E S T R E P L I E S (Newest First)
Binary 1011001101
Posted - Apr 06 2007 : 4:16:23 PM Ive got a problem with it now, I forgot the diode across the flyback transformer to stop inductive kickback, but when I put a diode in it shorts through stopping it working. The diode does work and it is put the correct way around, Also I have tried a fast switching shottkleys. Any ideas why?
Binary 1011001101
Posted - Apr 03 2007 : 10:20:47 AM Its not that hard, all you need is some motivation and lots of patience.
Posted - Apr 02 2007 : 8:58:25 PM haha nice I've always wanted to build one of thoes... Cool stuff!
K
Binary 1011001101
Posted - Apr 02 2007 : 2:03:57 PM I accidentally touched it today with holding no metal, it hurts.
Posted - Apr 02 2007 : 10:36:29 AM Looks neat...You can never safely draw sparks to your fingers. At the minimum, you need to hold a metal object and draw arcs to it instead of your skin. However most Tesla Coil people frown on that since you can get harmonics of 60Hz from other sources and end up hurting yourself because of it.
