| yo_tyler |
Posted - Oct 30 2005 : 01:06:06 AM Hello, im back from a long break from this forum.
I need some help with my motor. When i add gas to the tank, it floods the carb, and flows out the air filter. What could be causing this?
Here is the info on the engine: Model -122702 Type - 314301 Code - 91112359 The engine is a Homelite Quantum Power 4hp, made by B&S.
Thanks in advance, and ive got a headach from this color scheeme.
"If the women don't find you hansome, they should at least find you handy" -Red Green |
Posted - Oct 30 2005 : 09:50:44 AM You can set your browser to override the colours if you want. I have found that in the past 11 years, about 1% of people have had issues with the colours. Mostly it comes from a certain combination of video card and monitor.
As for your engine, I assume this is a float carb? If so then the metering seat and needle that controls the level in the bowl are worn. Or the float is stuck. Either way, you need to get a rebuild kit for the carb...
