 Mechanical Things
 another go-kart question
Alien Posted - Apr 12 2004 : 9:35:10 PM
I'm wondering how I can hook up the clutch to this go-kart: http://www.skynet.ie/~steviewdr/woodenkart/chassis9.jpg
Could i put it on the wheels axle directly
Andrew
13/m/Canada
Aaron Cake Posted - Apr 13 2004 : 09:13:50 AM
It will be difficult to use the belt as a clutch due to the slack required to allow it to slip...It will end up falling off the vertical pully...Three options come to mind:
1. Use a centrifugal clutch on the shaft of the lawnmower, and modify it to have a pully instead of sprocket
2. Use a centrifugal clutch on the axel....This is much more complicated as you must modify the clutch so that the output side is now the drive side. I don't recommend this.
3. Use a jackshaft with a clutch on one side (connects to the axel) and a pully on the other side (connects to engine). This is the approach I would take.
cirvin Posted - Apr 12 2004 : 11:48:19 PM
The pulley on the engine shoud be the clutch. Your clutch should be a belt clutch.
http://daxter12.topcities.com
