| n/a |
Posted - Aug 29 2003 : 1:11:46 PM Hello, For my jet-kart project, I need an oil pump... I figured the best thing to use would be power steering pump.
What would be a good, cheap, easily found 12V motor to power this pump? The power will be from a car battery.
Thanks in advance, Jonathan
Check out www.jetkart.cjb.net for my project on my dual jet powered go-kart! |
Posted - Aug 29 2003 : 4:17:53 PM Power steering pumps take alot of juice to run. You're going to need about a 3HP motor. Very large.
How about just using a thin oil (0W-20) and using a low pressure (carb) fuel pump? This is what I am planning on. You don't want too much oil pressure to avoid drag on the shaft...
| cirvin |
Posted - Aug 29 2003 : 2:18:23 PM i bet you can find a fan motor at a junkyard, or a power wheels mtor frm the power wheels car. you could also take the motor off a squrell cage blower and use compressor bleed air to drive it witch drives a belt to the pump
next stop: nobel prize winner! |
