| n/a |
Posted - Jan 11 2003 : 6:11:18 PM I have a 27 HP yarmar diesel engine with an altinator generating 80 ams dc current, but i also want to generate 120 volts ac. Can i use an electric motor being driven by way of pullys do the job?
| n/a |
Posted - Mar 22 2003 : 8:07:29 PM Hi,
The Yanmar is a 'marinised' engine, typically used on boats of one type or another.
It is likely that its principal use is drive a boat, and the owner probably has some mains items he would like to run also.
This may be why he/she mentions pulleys by way of a power-take-off, since the usual way for an engine driving a large alternator is direct.
The owner also mentions that this engine has an alternator capable of 80 Amps.
My guess is that this is a 12 volt peripheral and not the principal use of the engine, 80 Amps is a little high for most 12 volt alternators, but there are heavy duty ones for diesel engines.
Running a small generator from pulleys wouldn't be too difficult, but aiming at 50 Hz would be very awkward on a boat, manouevering often means changing from low to high revs.
Since SHEHERB has faded away, we are not likely to find out one way or another.
Regards, John
Edited by - john1 on Mar 22 2003 8:08:10 PM |
Posted - Mar 22 2003 : 2:05:04 PM A UPS would be a good intermediate to use while you fire up the generator, but it cannot provide the constant high power he wants to use the generator for...Actually, come to think of it, you could hook up a generator in parallel with a UPS battery and make a good emergency power system out of it...Cool, maybe I will do this.
| n/a |
Posted - Mar 21 2003 : 6:34:05 PM Hi sheherb,
I doubt that you will check back, its been a couple of months now, but i thought i would chip in anyway.
I think your best bet for this would be a UPS unit.
John
Posted - Jan 12 2003 : 12:05:18 PM Yep. Motors will run in reverse to generate....Not sure the best type to use, but a search on "Google" for "home brew generator" or the like should turn up what you need.
