 Go-Cart Motor
n/a Posted - Mar 29 2003 : 4:00:04 PM
Is it easy to use a lawnmower motor in a go cart? What im wondering about is the gear ratio and the fact that the lawnmower motor is sideways to the way we need it.
Also Im wondering if it has enough power.
I have an electric motor as well but I don't know how to use it.
n/a Posted - Apr 06 2003 : 4:47:13 PM
Im not sure, but i'm thinking of building a go-cart this summer, and usually there some motors for sale on the side of the road on the way to my cottage.
Aaron Cake Posted - Mar 30 2003 : 11:03:24 AM
Depends on the engine...Vertical shaft engines are almost useless, so you need a horizontal shaft. Two stroke verticals can be turned on their side to make them horizontal, but then you need to reorient the carb so it is the right way up.
What type of engine were you looking at?
BEatonNo1 Posted - Mar 29 2003 : 8:04:26 PM
If you use a vertical motor then you will have to gear it so that it sits that way. the vertical 2 stroke motors dont seem to work side ways well and the same for the horizontal.
