 Spudguns
 Combustion Guns
 Sparker for your spud cannon
moody Posted - Oct 09 2005 : 12:44:30 AM
I made a sparker last week
mainly for lighting my metal working torches like the propane and OA torch but this circuit can be moded to work with a cannon
here are some pics in order of being built
http://photobucket.com/albums/y22/moody07747/New%20ETI/
its basicly a 5V input inverter from allelectronics.com for about $7
parts you will need:
- inverter - allelectronics.com
- momentary NO push button switch - allelectronics.com
- black plastic case - allelectronics.com
- 9V battery clip - allelectronics.com (yes this board can be run up to 12 volts on a scort use, i have run mine for 5 minutes continusly on a 9V battery and the battery is still working strong)
thats it
i would add a voltage multipier from an old TV or something (ebay has some) because the spark is really small and might not run through wires any longer than 7"
i have heard the VM works well with the board but will drain the battery faster
good luck
"I reject your reality and substitute my own" -Adam Savage (Myth busters)
