 Spudguns
 Combustion Guns
 how much hairspray?
the SPECIALIST Posted - Aug 12 2003 : 12:17:02 AM
hey guys i was wondering how much hairspray should go into a cumbustion spud gun. the thing is ive heard diferent things like" empty a can of hair spray into the cumbustion chamber" and "remember to only spray 4 second of hairspray into the spud gun"
which quote is the correct one?
n/a Posted - Aug 29 2003 : 1:15:37 PM
Ive found with my spud-gun, that instead of one continous shot for a few seconds, to do 3-4 short burst.... I couldnt get it to fire as well with one continous burst for 2-4 seconds... Only thing I could think of is the short time between allowed a little bit more O2 into the chamber... I dont know. So for me 3-4 shots at around 1/2 to 3/4 of a second.
Also, as far as brands, I perfer "White Rain" - Never had a probelm. Ive heard the cheaper the better, because of the more alcohol in it, but White Rain has been the best so far.
Check out www.jetkart.cjb.net for my project on my dual jet powered go-kart!
da-g-dog Posted - Aug 25 2003 : 01:22:10 AM
One thing to remember, the reason hairspray works as the combustible is that it uses butane as the propellant. I have found that buying a can of lighter refill butane and putting a spray tip on it works much better as it is all combustible.
Or you could plumb in a 1 lb. propane cylinder. Get a fitting to go on the cylinder followed immidiately by an open/close valve, run a length of braided steel hose ended by another open/close valve right at the combution chamber. open the last valve followed by the first one. Close the first one after about 5 seconds, then close the second one. Ignite, have fun.
Oh, for igintion, you could just use an old-school flint striker for a lantern. they work well and are dirt cheap.
Edited by - da-g-dog on Aug 25 2003 01:27:05 AM
Aaron Cake Posted - Aug 12 2003 : 09:25:33 AM
Emptying a can wouldn't be dangerous. In fact, it would be quite safe because it would never ignite. Too rich.
the SPECIALIST Posted - Aug 12 2003 : 01:17:06 AM
i sort of disregarded the site cause i thought emptying a can of hair spray would be dangerous. thanks for cleaning that up
BEatonNo1 Posted - Aug 12 2003 : 12:51:23 AM
well I only use a couple seconds worth...where ever you heard that you should use a whole can...well they have problems. you can see the hair spray comming out as your spraying it in, so spraying a whole can would be an utter waste.
