| ashveen |
Posted - Mar 17 2009 : 06:48:27 AM hi, im trying to assemble the cct Ringing Phone Light Flasher (http://www.aaroncake.net/circuits/pflash.asp) , but i need to modify the cct so as to activate a magnetic door latch, if there any configuration i need to know to be able to do this?
also, im unable to get the 2N27 opto isolator, instead the 2N26 is available. will that cause a problem in the cct.
for the C1 0.47uF 250V, 0.47uF 50V is available.
will the cct work if i use the components available to me? looking forward for some help thanks!!
| audioguru |
Posted - Mar 17 2009 : 11:48:50 AM quote: Originally posted by ashveen
The circuit is missing an important diode across the relay's coil that stops the transistor from being destroyed by the very high flyback voltage. Select a relay that the transistor can drive and with contacts rated for the current of the door latch.
quote: im unable to get the 2N27 opto isolator, instead the 2N26 is available. will that cause a problem in the cct.
The 4N26 is twice as sensitive as the 4N27 so it will work fine.
quote: for the C1 0.47uF 250V, 0.47uF 50V is available.
The ringing in my country is 90VAC with 48VDC. Its peak voltage is 175V. Your 50V capacitor will be destroyed. |
