| picboy |
Posted - Jan 24 2012 : 05:56:47 AM I have to measure voltage (0- 500v) and current (0 to 5a) using a PIC microcontroller. Since it takes 0 to 5v, how do i bring the voltage and current down linearly such that.. if i measure 5v, it is equal to 500v , 4=400v, 3=300v etc.. n the same goes for the current. plz help :)
thanks in advance..
| Autofashion |
Posted - Feb 10 2012 : 5:53:51 PM I was looking for a similar thing - check out the info at http://electronics-diy.com/70v_pic_voltmeter_amperemeter.php which I think you will find helpful. Just change the resisitor and you have 500v. Hope that helps. |
| picboy |
Posted - Jan 26 2012 : 01:50:31 AM Thanks :) will an HCPL 7510/7520 work? here is the datasheet: http://www.secomtel.com/UpFiles/Attach/2003/11/19/103521.pdf
Posted - Jan 24 2012 : 09:52:58 AM Google "voltage divider". Though with 500V you may wish to use an opto-isolator.
As for current, you place a low value resistor in line with the current draw and measure the voltage drop accross that resistor. |
