 charger
hellion Posted - Apr 04 2010 : 12:39:09 PM
I am using my 600va ups as a Inverter for a 12 v 200 ampere battery but its not working properly how can i modify my ups to make it work properly with my Battery??
(Edit...Move to Power Supply)
audioguru Posted - Apr 05 2010 : 1:26:31 PM
Since its output is only 100W for only 5 minutes then either its battery is not being fully charged or its battery needs replacement.
A lead-acid battery that was discharged too low is ruined.
A lead-acid battery that has been sitting around for months without a charge is ruined.
hellion Posted - Apr 05 2010 : 10:13:51 AM
it used to work fine before but now it doesnt work for more than 5 minutes i am using some 100 watt total load
audioguru Posted - Apr 05 2010 : 09:06:57 AM
You forgot to tell us what is not correct.
Is the voltage from the inverter too low?
Is the run time of the inverter not long enough?
