| e3nigma |
Posted - Jan 28 2010 : 2:21:00 PM How do you resist volts without resisting amps? And how do you resist amps without resisting volts? Thanks |
| e3nigma |
Posted - Feb 01 2010 : 3:59:11 PM Ok. Thanks that helps. |
| audioguru |
Posted - Feb 01 2010 : 11:39:42 AM Most loads draw only as much current as they need. You can use an LM338 adjustable voltage regualtor IC set to 2.6V. Its max output current is 5A. Its input can be 5V or a little more.
A resistor in series with a load reduces the voltage and reduces the current. A resistor that is parallel with a load does not affect the load but increases the current from the power supply. |
| e3nigma |
Posted - Feb 01 2010 : 09:43:36 AM Ok... I'm trying to build a power supply that consists of 2.6 volts at 3.6 amps. Can someone help me get started with some ideas? Mcuh appreciation.
Someone told me that having resistors in series reduces the volts and having them in parallel reduces the amps. I this true?
Thanks |
| audioguru |
Posted - Jan 28 2010 : 4:24:25 PM You can regulate the voltage or you can regulate the current but not both at the same time. The load resistance and supply voltage across it determine the current. If the load resistance is fixed then the voltage determines the current in it. You can reduce the current by reducing the voltage or increasing the load resistance. |
