 Light/LASER
 Request
solo p Posted - Feb 28 2014 : 10:14:19 AM
please i need the list and the discription of all the components of a 150W energy saving bulb
(Edit...Move to Light/Laser)
audioguru Posted - Mar 03 2014 : 11:53:57 PM
150W is a lot of power for a light bulb. A street light?
Maybe it is mercury-vapour or sodium-vapour? Halogen? Xenon?
Aaron Cake Posted - Mar 02 2014 : 10:28:24 AM
That's going to depend on the type of bulb.
If it's an incandescent, then it's nothing more than a filament suspended with wire between two conductors in a bulb filled with a gas mixture.
If it's a fluorescent, there will be a small circuit which just rectifies the mains to DC, then runs it through an oscillator and transformer to make about 400VAC. The transformer typically has a higher voltage winding which is used to start the bulb at a higher voltage. Here's a great page which describes the typical circuit:
http://www.pavouk.org/hw/lamp/en_index.html
If you are referring to LED, then typically the mains is rectified to DC and then sent through a PWM circuit to regulate the voltage for the LEDs.
