 Jukebox Transformer
Ggrima
Posted - Aug 29 2014 :  9:14:01 PM  Show Profile  Reply with Quote
I am hoping to buy a jukebox from the US and bring it to Australia. It contains a 25.2V CT 2.0A Heavy-Duty Chassis-Mount Transformer with Lead
Model: 273-1512 | Catalog #: 273-1512.
Can anyone confirm whether the transformer will function correctly given that the US have 110v 60Hz and Australia has 220v 50Hz? I will be using a step-down transformer for the voltage but will the difference in Hz be a concern? I appreciate any help you can offer. Thanks in advance.
Posted - Aug 30 2014 :  10:32:40 AM  Show Profile  Visit Aaron Cake's Homepage  Send Aaron Cake an ICQ Message  Send Aaron Cake a Yahoo! Message  Reply with Quote
The transformer will heat more due to the lower frequency but otherwise operate fine.
But, since 25V CT (24V CT, close enough) is a very common value, why not purchase a transformer designed for 220V at 50Hz and swap it in? That way you can avoid the external step down transformer. Keep the original handy if you want to put it back to stock.
Ggrima
Posted - Aug 30 2014 :  7:07:17 PM  Show Profile  Reply with Quote
Hi Aaron
I like your idea. Can you please excuse my ignorance and let me know of a viable replacement model number that I can easily buy online? Thanks for your help.
Ggrima
Posted - Aug 31 2014 :  10:17:15 AM  Show Profile  Reply with Quote
I think I found a solution with this one:
Carrier Bryant Transformer HCTY08H2AF05102 Totaline Transformer 120 240 48024v
Cheers.
somi
Posted - Sep 15 2014 :  05:20:27 AM  Show Profile  Reply with Quote
Thanks its 100pf. I have buit the circuit and it works very well.It even increases my solar panel current by 1 amp. Thanks
http://www.pass4sure.co.uk/352-001.html
http://occ.edu/
http://www.arm.com/
http://www.rockefeller.edu/
