 Sound/Radio
 Aircraft Radio Communications Receiver
FlyingDutchman
Posted - Aug 16 2010 :  10:54:59 AM  Show Profile  Send FlyingDutchman a Yahoo! Message  Reply with Quote
Hi, I'm quite new in electronics, but I wanted to try this circuit anyway. I used a 1N60 Diode, but I was wondering if the diode in the circuit is placed correctly. And also, I see +9V, but where should I place the -?
Thank you very much
Posted - Aug 17 2010 :  10:20:10 AM  Show Profile  Reply with Quote
The circuit can use any germanium diode. The diode is shown correct for an AM detector diode.
It connects to the circuit's ground.
The frequency is very high so it will not work if you make it on a breadboard.
FlyingDutchman
Posted - Sep 10 2010 :  2:59:04 PM  Show Profile  Send FlyingDutchman a Yahoo! Message  Reply with Quote
and do you have any ideas of what kind of speaker I should use?
Posted - Sep 10 2010 :  6:30:36 PM  Show Profile  Reply with Quote
The very simple circuit drives a power amplifier that drives a speaker.
You could use an LM386 little power amplifier IC and a little 8 ohm speaker.
